I'm sure I've asked for this before, and still can't understand why we haven't got it..
Please can we have the ability to put a global audio effect that effects all audio from VDJ.
This would be ideal for effects like compressors and eq which you would normally setup once for your equipment / venue then not mess around with.
It would also be useful for adding extra audio sources such as microphone effects and more advanced samplers.
Since the effect layout has changed in recent versions, it should be easy to add an 'Activate on All' button under the effects screen, and the existing plugin API should be usable.
geposted Wed 20 Dec 06 @ 12:06 pm
We can already write main channel effects, but no one has made one yet.
At the moment we can't modify the microphone - the team said we can't with the current engine. It would me a great thing, because there's NO Great DJ without a microphone!
geposted Tue 26 Dec 06 @ 1:58 pm
just a little tip
download the dj cel registy patch
and dissable clear fx on load :)
run an fx on two channels or an mic
it sticks :)
until you deativeate
so more or less the same result :)
good luck !
it sticks :)
good luck !
geposted Tue 26 Dec 06 @ 9:06 pm
