Forum: Old versions
Topic: PLEASE HELP ME !!!
My idea was to create a skin, like the multi instand skin.
Two vdj's running in the same time.
I want to create a skin where you can push a button, so that the browser uppears. and when again push the button, the browser will be gone.
Is that a dream? or can i make this real?
ps: sorry for my english.
thnx anyway
geposted Wed 04 Aug 04 @ 3:18 pm
not sure if brownser can be hidden..
Fruit? ;) Speedland? ;) any other? ..
yes fruit .
I's hidden when you start vdj.
Then i have to push a button and there he is...NOT...
sorry dj in norway thnx for answer.
someone else maybe..???
Maybe you should make the browser in a 'panel', those can be hidden at a click of a button. So I think it can be done, although not sure.
maybe...
may i ask you to try it for me. i'm not that smart.
my thanks will be verrrrrrrrrrrrry verrrrrrrrrry special.
ignore the english..lol...
hehe... wait, a little bit.
And some of the skin people will answer you.
I don't think "brownser" can be in a pannel, sorry... but I'm not sure :)
If you wait a little, I'm sure some of the skin designers will answer you :)
Hello,
Your problem is not really the pannels : actually you can't have more than two players per instance. It means there's actually no controls to define the players 3 and 4, so It won't bee possible sorry.
But you can still work on a multi instances skin, but it must be two skins instead of only one...
FRUiT94
I know that....
But if you can hide the browser you create more space for the channels
now i have the browser under a button.
it works. only....when you are sliding with your mouse over the browser, it wil appear. And i need to place al the other buttons from the channels in another pannel.
That's a lot of work.
Final thought...
It's not importent enough to do so much work for a little thing like that.
anyway.....
thnx for answering..i lurned a lot if this.
by the way....in the last 4 weeks i uploaded 3 skins.
and non of them are placed on the site.
