Forum: Old versions
Topic: only decodes while playing
stefdjPRO InfinityMember since 2006
can anyone help?
when i drag a song on to vdj it will not load on to the window. it used to load up straight away instead now it decodes while playing the track, this is the case for video or just songs. I have the video setting to decode while hidden as it has always been, but all of a sudden it isnt decoding................any ideas?
just realised this happened after i enabled eq in monitor in registry , however disabling it doesnt remove the problem
geposted Sat 23 Dec 06 @ 6:20 pm
Go to VDJ options, set max load to longer than the length of the songs you are trying to play ;)
geposted Sat 23 Dec 06 @ 6:35 pm
thanks dj-in-norway,
i feel like an idiot now, that simple.
i have never touched that setting so was a bit confused.
thanks anyway
geposted Sat 23 Dec 06 @ 6:38 pm
No prob;) you arent the first who's missed that one :)
geposted Sat 23 Dec 06 @ 7:13 pm
It seems to happen if you use the Registry tool. I too had it happen to me this weekend!! You weren't the only one.
geposted Sun 24 Dec 06 @ 1:58 am
