there's a new firmware available at www.numark.com for our iCDXs:
"VERSION 39: Adds improved compatibility with HFS+ formatted iPods and Drives"
here is the direct link: http://www.numark.com/updates/iCDX_ver39.zip
and here the copy paste of the info page:
it's funny, I had version 33.... ¿prior to the first shipping? :P
Quote :
iCDX SOFTWARE
To check the current software version in your iCDX, hold PROG and turn the parameter knob until you see "VERSION NUMBER", the press the parameter knob in like a button. The software version is the number after "iCDX-".
For example, if the display reads 'iCDX-039', then your current software version is 39.
To update the software in your iCDX...follow these steps:
1. Remove any discs from the unit
2. Power up the unit while holding PROG
3. When the unit displays “NO DISC”, insert the OS update
4. The CD will be ejected after only a few seconds but the update will take a few minutes. Check the top right of the display; while the update is in progress you will see numbers counting up
5. Once the update has finished the iCDX will reboot and is ready to use
This software is for iCDX only
VERSION 36: First shipping code.
iCDX SOFTWARE
geposted Sat 23 Dec 06 @ 7:45 pm
good news for icdx users
a long going thing with hardware companys is they are clueless what they ship out;)
with firmware
with firmware
geposted Sat 23 Dec 06 @ 10:27 pm
Another update from numark, now it's available for download v40, which gives improvements in startup and performance. Haven't tried yet, but any iCDX owner... you are advised about the new version.
geposted Fri 19 Jan 07 @ 1:34 pm
Quote :
VERSION 40: Startup and Performance improvements
http://www.numark.com/updates/iCDX_ver40.zip
geposted Tue 06 Feb 07 @ 12:32 am
