I installed the 32-Band equalizer and it appears that to only can be activated with deck at a time… Not the total output of VDJ.. The means if I want t to work with deck 1 n 2,, I need to switch the settings manually every time.. Please tell me I’m doing something wrong..
Thanks John
Thanks John
geposted Mon 25 Dec 06 @ 6:39 am
enable it on both decks on 4.2 :)
press the 1 and 2 button :)
geposted Mon 25 Dec 06 @ 12:17 pm
Yes I did install 4.2
On the skin or under sound effects?
Under Sound Effect I selected 32-BEQ and only able to select left or right deck at a time.
On the skin, drop a song on the deck, song ends, add another song, the effect turns off… It need to stay on.
geposted Mon 25 Dec 06 @ 1:09 pm
thenk you
geposted Thu 18 Jan 07 @ 8:09 pm
You'd better use an external EQ... maybe included with the mixer!
geposted Thu 18 Jan 07 @ 8:37 pm
LPEASE I WILL LIKE TO DOWNLOAD THE EFFECTS
geposted Thu 22 Feb 07 @ 10:33 am
I WILL LIKE TO UPDATE MY VIRTUAL DJ
geposted Thu 22 Feb 07 @ 10:34 am
then please buy the product and you will be able to have both
hope to see you with us soon
geposted Thu 22 Feb 07 @ 12:04 pm
hey sky.. I'd like some free money please...
geposted Fri 09 Mar 07 @ 2:50 pm
sure il go pick some off my tree right now =D
geposted Fri 09 Mar 07 @ 4:04 pm
how can i download this 32 band eq?
geposted Wed 28 Dec 16 @ 8:10 am
I don't know about a 32 band EQ, but here's the link to the 30 band EQ which is pretty awesome
https://virtualdj.com/plugins/?addonid=16705
best
ray
best
ray
geposted Wed 28 Dec 16 @ 10:02 am
