Is there a way to have the 32 or 16-Band Equalizer
enable on deck 1 &2 all the time without having to select the effect button every time you add a song.
Thanks
Thanks
geposted Mon 25 Dec 06 @ 2:26 pm
Thanks
Thanks
Download DJCel's registry tool, and un-check the Clear Effect on Load, then apply and try again.
https://virtualdj.com/addons/download.html?addon_id=2170
cstoll
geposted Mon 25 Dec 06 @ 3:51 pm
Ware do I install it
thank you
thank you
geposted Mon 25 Dec 06 @ 4:17 pm
Save it to your VirtualDJ folder and then create a shortcut to the desktop.
*Actually it doesn't matter where you install it as it just makes registry changes for you.
If you have never used it, you will like some of the registry options.
Have fun.
cstoll
Have fun.
cstoll
geposted Mon 25 Dec 06 @ 4:34 pm
