Forum: Old versions
Topic: Resolution problem
I had left my VDJ on idle for a few hours, and I had it minimized from full-screen mode . When I clicked it, it wouldn't respond, (Program Not Responding) after about a few minutes of waiting, it finally loaded, but by then I have chose to end the program, after that, my screen resolution has been messed up. It's stuck at what looks like 800*600 (and its set in properties to 1024*768).I've restarted my computer. I tried switching the resolution. I un-installed my graphics card drivers, then re-installed, and nothing has changed. Is there any previous happenings of this?
geposted Tue 26 Dec 06 @ 6:58 am
sbangsPRO InfinityMember since 2004
try a reinstall of virtual dj
geposted Tue 26 Dec 06 @ 12:51 pm
Tried it, and nothing happened. It's not just VDJ that has reolution problems, it's my whole entire screen. Firefox, messengers, anything. Something I failed to say in my last post.
geposted Tue 26 Dec 06 @ 9:29 pm
lower ur screen resulotion on settings
and reboot then raise them
may fix it :)
geposted Tue 26 Dec 06 @ 9:32 pm
That didn't work either.Hmm, I can't think of anything else.
geposted Wed 27 Dec 06 @ 6:01 pm
can the card be removed ?
if so try reseating it
aslo try reseting your bios
on boot press F1 or 2 and look for load best settings :)
geposted Wed 27 Dec 06 @ 8:00 pm
