Forum: Old versions
Topic: VDJ doesnt remeber all Songnamechanges or comments
roedelPRO InfinityMember since 2006
Hi, after renaming the songnames by clicking the right mouse, adding comments or cuepoints the software sometimes(!) can´t remenber after starting the application again?!?!?!
Very frustating after hours of cuepointsetting!?! Is there a trick I don´t know?!?!?
geposted Tue 26 Dec 06 @ 1:58 pm
cstollPRO InfinityMember since 2004
If you have the read and write ID3 tags Enabled? - Disable those choice in the Config / Options tab.
geposted Tue 26 Dec 06 @ 4:03 pm
Disable??? I always thought it has to be enabled to modify the tags?!?
geposted Tue 26 Dec 06 @ 8:00 pm
Make a keyboard shortcut to Save_database. Make sure you do this BEFORE exiting VDJ after adding and re-naming. After I did this I haven't had a corrupted or missing database since.
geposted Tue 26 Dec 06 @ 9:48 pm
edsalPRO InfinityMember since 2006
Hey Roedel
I had that problem too. I had everything enabled, BUUUTTT, I was scanning and renaming in the actual music folders!!! Doing that did not save anything for me. Everytime I rescan the HD now, I make any changes to any files that need changing under the "global Database". Don't know if that was a bug, but it worked for me!!!
ED
geposted Fri 29 Dec 06 @ 1:55 am
Meant "Local Database", not Global database.---Sorry
ED
geposted Fri 29 Dec 06 @ 7:47 pm
