Forum: VirtualDJ Plugins
Topic: 2 amazing VST plugins
on the following website you'ill find a VST called Mr green, this is a filter very easy to use like a kaos pad or vdj tk filter plugins, works like a charm on the 4.2:)
http://klanglabs.siliconemusic.com/
you could also find a VST named Daft funk who produce somes effects on the rythm.
all is free.
geposted Tue 26 Dec 06 @ 9:47 pm
Good, good, good!
Nice to know are tested for 4.2 by someone.
I'll try them later.
geposted Wed 27 Dec 06 @ 10:39 am
TexZKPRO InfinityMember since 2005
Good! I really need a filter!
geposted Wed 27 Dec 06 @ 3:31 pm
Thanks man! These are really cool!
geposted Mon 08 Jan 07 @ 4:21 am
I used Mr. Green many times working fine with VirtualDJ.
When you activate it, maybe you have a small "freeze" (about 1 sec.) that makes your body cold (if you're live).
Yesterday at VirtualDJ Radio, I used it and when moving the circles to have the effect on a track VirtualDJ nearly hanged, it started to loop everything and before VirtualDJ freezed I could clck to desactivate the effect.
It lasted about a minute to come to normality (it means, one minute still looping everything).
My PC was just powered up to shoutcast minutes before, so quite clean of memory usage and all of this.
So, test it much before work live with it.
It was the first time it happened to me, I used other times working fine. :¬)
geposted Tue 27 Mar 07 @ 10:45 am
