I have WXP, Soundblaster Extigy(3D) and Internal soundblaster(3D too).
I use external mixer.
When I use version VDJ 1.08 with S-Extigy, front and rear sound go well.
In version 2.00, front and rear sound mixes - front channel in rear and rear channel in front
(at the same configuration as in 1.08) :(
I tried internal soundblaster, then 2 soundblasters, no results.
I tried everything... :(((
geposted Thu 05 Aug 04 @ 10:24 am
are you using the demo? that would be version 2.01. If not you should update your software to 2.01.
Maybe that helps...
Maybe that helps...
geposted Thu 05 Aug 04 @ 10:42 am
mogii:
You should enter your serial in your profile in order to appear as Full version user and get help from us.
geposted Thu 05 Aug 04 @ 10:50 am
I have no serial, this version I downloaded.
Wrong demo?
Wrong demo?
geposted Thu 05 Aug 04 @ 11:28 am
HUM HUM!
In fact, you can't have separate outputs with demo versions:
neither with VDJ 2.00 demo... nor with 1.08 demo!
You need to buy the full version to be able to connect VDJ to your mixer.
geposted Thu 05 Aug 04 @ 1:18 pm
so you have to have a mixer in order to use this program? You cannot just have speakers and heaphones hooked up?
geposted Thu 05 Aug 04 @ 11:18 pm
No, you can use vdj as is, no extra controllers needed. Just download the demo and see if your setup works with the software. Keep in mind though that there are many more options in the full version to make things work.
geposted Thu 05 Aug 04 @ 11:22 pm
but from what ive been reading you cannot use it without a splitter and stuff like that.
I want to be able to have one desk play and then be able to listen to the other desk on my headphones. And from what ive been reading i need to buy a splitter or something. I have alot of questions about this but it seems the admin here will not help because i have not yet purchased the program. =(
geposted Thu 05 Aug 04 @ 11:25 pm
I've just checked the comparison list, and there it states that you can use a headphone.
https://virtualdj.com/products/comparison.html
I have the Hercules DJ Console and VDJ, and there I can prelisten the other table before mixing.
hope this helps a little...
geposted Thu 05 Aug 04 @ 11:34 pm
you must have the virtualdj full version to use the preview (or external mixer) feature..
geposted Fri 06 Aug 04 @ 2:14 am
Sigh........... well.... i guess I'll just have to trust in the knowledge of the staff and just buy it and hope you all can help me out...... =/
geposted Fri 06 Aug 04 @ 2:16 am
Ok ok, one last question. I have sound blaster audigy 2 zs. Will this be sufficient to be able to have one desk play on my computer speakers and then be able to listen to the other desk over my headphones?
geposted Fri 06 Aug 04 @ 2:18 am
This card will be more than enough if you want to be able to cue a song (pre-listen in headphones while the other song is playing on the speakers), since it has 5.1 output.
You can easily configure VirtualDJ to do that with the full version (you do not need additional hardware).
macourteau
macourteau
geposted Fri 06 Aug 04 @ 2:28 am
Thank you! Finally a straight answer (no offense). I will be purchasing this tomorrow then. Thanks again!
geposted Fri 06 Aug 04 @ 4:52 am
Look at me look at me!!! I bought it!!!
.........now to install...........hehe
(sorry for hijacking this post btw..... =) )
geposted Fri 06 Aug 04 @ 6:14 am
Audio: No problem :)
Welcome with us and Good Mixs too !!!
geposted Fri 06 Aug 04 @ 7:51 am
Thanks! Not sure about the good mixes part (im still learning) but i love this program to death!!!
Im having a helluva time orginizing all my files.
geposted Fri 06 Aug 04 @ 9:07 am
Congratulations, and welcome :)
geposted Fri 06 Aug 04 @ 11:33 am
Thank you all for the warm welcomes!!!
LoL, please dont be suprised if you see me posting questions alot. =)
geposted Fri 06 Aug 04 @ 3:20 pm
Post every questions you have and all of us will try to answer.
Congratulations and welcome aboard.
By working together and by helping the team to increase VDJ possibilities and adapt it to customers wishes we all will reach a new dimension of mixing technics.
Clax
Clax
geposted Fri 06 Aug 04 @ 10:26 pm
