ive got a hercules dj control mp3 and was wondering how to prelisten to 1 song though my headphones and play another through my speakers!
geposted Wed 27 Dec 06 @ 6:15 pm
open Hercules DJ Mixer (The alien head) =
Change normal to DJ =
You will 3 sliders = 1-2, 3-4, 5-6
Choose a channel for headphones and plug in…
Also turn the volume to max on all sliders.
geposted Wed 27 Dec 06 @ 6:27 pm
what alien head!
geposted Wed 27 Dec 06 @ 6:35 pm
look in the hercules folder in C/Programs/hercules
geposted Wed 27 Dec 06 @ 6:38 pm
or double click on an icon which says "dj" on ur tast bar
or look in the windows control pannel :)
failing that look in the folder
geposted Wed 27 Dec 06 @ 6:45 pm
cant find it, iv got version 3.1 dj console. im new to the software thing ha!
geposted Wed 27 Dec 06 @ 6:49 pm
please update to 3.4
is it not in the program folder?
geposted Wed 27 Dec 06 @ 8:58 pm
cud u give me a step by step guide on how to do the preveiw thing please, ur a great help ;)
geposted Thu 28 Dec 06 @ 5:33 pm
basicaly with a 4.1 + soundcard
plug the headphones in one output and the master into another
then when you wish to tune to that channel
say Deck A
lightly press the headphone button for A
when ur done release
note to have the preview so that when you press it it stays on then press it again to turn off
or to use an external card to two cards you need pro
say Deck A
geposted Thu 28 Dec 06 @ 5:41 pm
iv got a laptop with a internal and external soundcards, the built in 1 is a realtek high definition audio and my external 1 is a creative sb audigy 2 (wdm)
geposted Thu 28 Dec 06 @ 5:59 pm
to use more then one ul need pro
geposted Thu 28 Dec 06 @ 6:15 pm
wot if i was just to use the 1 built in my laptop?
geposted Thu 28 Dec 06 @ 6:21 pm
Your free version supports the use of ONE soundcard.
To prelisten that ONE soundcard needs to be a 4.1/5.1 (surround) card.
This way you will have main out on channel 1 out, and prelisten on rear out.
You can get a cheap usb surround card, and it will work great:)
geposted Thu 28 Dec 06 @ 6:26 pm
