Forum: Old versions
Topic: Another cue question from a newbie
gordonaHome userMember since 2006
Hi Folks,
I am trying out the demo and so far am very please with the programme but I can't seem to get my head around editing the start/end points for use in Automix.
I have let VDJ analyse a small group of mp3s and have tried using the menue under the BPM button to set the points individually. I have the "Write VDJ Tags" enabled and when I exit VDJ it saves the database.
However, when I select Automix the cue points are all over the place again and the tracks start and end at odd places.
I have searched through the manual and the many topics in the forum on cue points and, to the best of my knowledge, I am doing all the right things.
What am I missing?
Thanks in advance,
Gordon
geposted Wed 27 Dec 06 @ 7:01 pm
sbangsPRO InfinityMember since 2004
heya are you closing the program down fully each time?
and have u tried closing the program after you have applied cues?
geposted Wed 27 Dec 06 @ 7:11 pm
Wow skyfxl, that was an Impressively fast response!
The answer is yes to both questions. I have set the cues then exited the prog fully and watched it save the database. On re-starting the prog again the cues are displaced from where I set them.
Gordon
geposted Wed 27 Dec 06 @ 7:18 pm
with 4.2 yes ?
is it installed in the defualt folder :)?
geposted Wed 27 Dec 06 @ 8:48 pm
