Anyone having any problems with the Fader start effect? I have the latest version of the plugin and it doesn't appear anywhere in the effects. I liked using it in the past as it was very practical.
geposted Thu 28 Dec 06 @ 1:09 am
check if it is in the sound fx folder in the virtual dj program folder
geposted Thu 28 Dec 06 @ 1:10 am
What's the name of the effect, I haven't seen it in the plugin download place?
Did I miss something (obviously did)?
geposted Thu 28 Dec 06 @ 8:07 am
i belive its callled fader start
geposted Thu 28 Dec 06 @ 1:20 pm
Yup, ok, I got it. But even after reading about it,
I'm still not sure exactly what it does?
What is it intended to do; in simple terms?
geposted Thu 28 Dec 06 @ 10:33 pm
fader start
means that the music doesnt start until you move the fader like on cd mixers :)
say i move the fader to deck B , it starts
A stops
A stops
geposted Thu 28 Dec 06 @ 10:39 pm
It is in the sound effects, but doesn't show any on or off capabilities , parameters, or any way to activate/unactivate it?
What may be the problem, here?
geposted Fri 29 Dec 06 @ 7:59 am
Do you use Windows XP Sp2?
I have just verified: FaderStart still works with VirtualDJ v4.2r1
geposted Fri 29 Dec 06 @ 8:10 am
Yes. Service pack 2 is installed, should it be or should it NOT be.
You were not very clear as to which?
geposted Fri 29 Dec 06 @ 8:59 am
It works as supposed to with sp2 installed..just answered in other post and confirmed after testing it
https://virtualdj.com/forums/62133/General_Discussion/2_questions_.html
maybe thats why he hasnt chirmed in again yet ... its hard remembering double posts ...heheh
j/k
j/k
geposted Fri 29 Dec 06 @ 8:47 pm
Mine still doesnt work. Why is that?
geposted Fri 29 Dec 06 @ 9:20 pm
I just d/led it, and it shows up in the window where you select the effect, but when you select it, it go to the brake effect instead. :(
geposted Sat 30 Dec 06 @ 5:06 pm
i will compile the dll again in one week with my old computer.
geposted Sat 30 Dec 06 @ 5:36 pm
actually, it pauses instead of stopping the song ;then it restarts the song where it left off @ instead of @ the beginning
geposted Mon 01 Jan 07 @ 12:22 am
In my case, it shows up in the effects, but doesn't actually show any means of being able to activate or make any adjustments of any kind whatsoever.
Excellent effect otherwise, though - I've used it to good effect in many of my mixes.
geposted Mon 01 Jan 07 @ 6:32 pm
Change the option on deck 1 and 2 with sliders: select "stop" instead of "pause"
geposted Tue 02 Jan 07 @ 11:39 pm
@ dj cel... that should do it;
I only loaded the plug in to test for foamgod;I personally have fader start on my external mixer (on the crossfader and on the line sliders =-P
geposted Wed 03 Jan 07 @ 4:23 am
Hi guys
Just want to now how to leave it on full time...when you load a new song it deactivates the Fader start and you have to turn it back on
Later DJ MikeD
Later DJ MikeD
geposted Wed 03 Jan 07 @ 4:47 am
download dj cels
registy tool
and dissable "clear Fx on load "
https://virtualdj.com/addons/tools.html
that way it will always run
Regards
Simon
registy tool
Regards
Simon
geposted Wed 03 Jan 07 @ 12:10 pm
Thanks Man I will give that a trY
Sky you are quick to answer..
Later
DJ MikeD
Later
DJ MikeD
geposted Wed 03 Jan 07 @ 7:15 pm
