Is This one I MK1 /?????
"Hercules DJC Mapper v4.1.1"
v4.1: It uses the new Mapper SDK for VirtualDJ v4.1
v4.1.1: some bugs corrected
Or Is This one I MK1 ???????
"Hercules DJC Mapper v4.0 for VirtualDJ v3.4 and v4.0"
Now include a new graphical interface to map the DJ Console 1, DJ Control mp3 & DJ Console MK2:
* You can change the data in live
* You can save/load settings in different files
* You can affect the function effect_slider() on the stick (affect the two opposite button)s
* You can use the jog to move a slider
geposted Thu 28 Dec 06 @ 3:56 am
this one
this one
geposted Thu 28 Dec 06 @ 2:07 pm
Hi Sky,,, I wasn’t told this was the wrong Mapper “Hercules DJC Mapper v4.1.1" as we found it to be.. Needless to say, I reinstalled this Mapper but I’m still unable to map the tremble as gain……
The MK1 is performing like it should and I can live with the results. I
bugs me that I can’t get the Mapper to do what I want…
One other thing,,, Is it there a way to transition from deck to deck with the effect while playing karaoke
All I’m able to do is fade in the next track??. Not that exciting..
geposted Thu 28 Dec 06 @ 3:00 pm
do you mean add transitions to the KJ?
geposted Thu 28 Dec 06 @ 4:36 pm
Yes
geposted Thu 28 Dec 06 @ 5:36 pm
yes just load them onto each deck then apply video transitions like normal :)
geposted Thu 28 Dec 06 @ 6:20 pm
Have you tried doing it with mp3g’s? All I get is fade in and out effect… A couple of versions ago I remember being able to transition with different effects. This is the first time I’ve tried this option in sometime..
And yes I chose an transition, activated it.
Could you see it works for you.???
geposted Fri 29 Dec 06 @ 12:05 am
on the fx tab you can enable multipul fx give it a shot :)
geposted Fri 29 Dec 06 @ 12:10 am
hi,thinking of getting a hercules mk 2...will it work with my atomix mp3 version 2.3??????
geposted Fri 25 Jan 08 @ 2:46 pm
Please dont ask questions in non related topics.
it will not work in atomix mp3 but it includes VDJ home edition.
geposted Sat 26 Jan 08 @ 4:55 am
i want to download the Hercules Mk1-Mk2-Mk3 Mapper but it says my licenses dont allow me to. how do i get the licenses?
geposted Fri 02 Jan 09 @ 4:03 pm
U need to purchase the software;)
Hope to see u with us soon;)
geposted Fri 02 Jan 09 @ 4:06 pm
i downloaded virtual dj and i put my serial nomber but when i installed effects i put them in effects file and they are dll and when i open virtual dj they occr but they dont work what should i do?
geposted Sat 18 Apr 09 @ 6:20 am
sorry only registered users can use effects, have you bought the software or are you using a trial version....
geposted Sat 18 Apr 09 @ 6:51 am
