MANY SKINS GIEVING PROBLEM IN 2.01 JUST FIND OUT TODAY MIX STATION SV AND OTHERS I HAD TO UNINSTALL VDJ NOW IT OWNLY WORKS WITH THE DEFAULT IS THERE ANY SKIN THAT SUPPORT 2.01 ?
geposted Thu 05 Aug 04 @ 10:48 pm
Try to lift your pinky of the shift key while typing. And yes, there are a lot of skins that work with 2.01. In fact, I just made two of them, but they are too big to upload (3.5Mb), so I have to find another way to distribute them.
But lots of skins work, and in the skins section you can see per skin which is 2.0 compatible. They work for me at least.
geposted Thu 05 Aug 04 @ 10:58 pm
I am using a mixstation skin and as of yet encountered no probs!
please tun off caps lock in future :)
geposted Fri 06 Aug 04 @ 12:05 am
