how can i set it to record over my mix while am working live ?
geposted Fri 29 Dec 06 @ 2:05 pm
choose master + mic
soundcard
mk2
on recording options:)
soundcard
mk2
geposted Fri 29 Dec 06 @ 6:11 pm
I tried this and other various combinations with no success. My setup is MK2 controller connected to laptop with VDJ and output from MK2 into peavey amp. The microphone is an AKG D880 MS and it is connected into the MK2. I have the levels set so that the microphone can be heard when I press the talkover button but when I playback the recording there is nothing of what I said recorded.
geposted Wed 17 Jan 07 @ 4:46 pm
have you tried this asign mic to input channels 1/2 on the mk2 control pannel
what happens now?
what happens now?
geposted Wed 17 Jan 07 @ 4:49 pm
will have to try this later as I am at work now. cheers
geposted Wed 17 Jan 07 @ 5:52 pm
Thanks skyfxl - that worked a treat.
geposted Thu 18 Jan 07 @ 12:03 pm
:) any time
geposted Thu 18 Jan 07 @ 12:05 pm
On a different note, I observed the "on air" text on the Hercules control panel lights up when I have engaged the talk over option on the MK2. This is a nice feature but unfortunately I am unable to minimize the control panel only close it. Do you know of any skin that includes this type of indicator as there is nothing on the MK2 itself to indicate that you have engaged the talkover button i.e. it doesn't depress or illuminate an indicator... cheers
geposted Thu 18 Jan 07 @ 12:31 pm
im afraid not :(
its not designed to
its not designed to
geposted Thu 18 Jan 07 @ 2:46 pm
