Forum: Old versions
Topic: New mixer
I was wondering if anyone knew if the numark cm200 usb mixer would work with virtual dj.
And if the crossfader on the mixer would control the one in the software??????
geposted Fri 29 Dec 06 @ 8:34 pm
sbangsPRO InfinityMember since 2004
it will act like dual soundcards
it it doenst have midi im afraid so it wont control the software
geposted Fri 29 Dec 06 @ 8:37 pm
mainedjPRO InfinityMember since 2006
sky, are you saying that with that mixer, someone wouldn't need a soundcard (firebox for example)?
I am just thinking backup purposes.
geposted Sat 30 Dec 06 @ 1:01 pm
this is a special mixer with 2 soundcards in the base of it :)
so it should be able in dual soundcard mode acept timecodes
or external mixing :)
but theres no midi control
i dont have one tho so i cannot confirm if it can support timecodes
but iv read about it here before
geposted Sat 30 Dec 06 @ 1:08 pm
Sky, I have the Numark cm200usb mixer but I can't see how could I connect tcv or tccd because I don't understand where line in is.
geposted Sat 30 Dec 06 @ 1:50 pm
okies
you can help test :--)
connect the timecode 1 to right channel , and timecode 2 to left
now get the two usb cables and plug them in
choose inputs timecode
soundcard two cards
and choose the cm200 2 times :)
now go to the config and see if you can see a timecode singal
if you cant it probaly means that its dual out only
geposted Sat 30 Dec 06 @ 1:55 pm
Unfortunately I don't have tcv yet. :(
geposted Sat 30 Dec 06 @ 2:14 pm
try playing music into it via the inputs :) , and choose by pass mode :)
by using keyboardshortcuts
if you get music it will work :)
geposted Sat 30 Dec 06 @ 2:33 pm
