Forum: Old versions
Topic: Mk2 Console problems
I have the dj console mk2 and everytime i use the knobs for the left deck specially the bass it returns it to the full - side .no matter what i do.
geposted Fri 29 Dec 06 @ 9:56 pm
sbangsPRO InfinityMember since 2004
could you be more specific please
when did this start
what config do you have?
for reset gain and match pitch? and match gain?
geposted Fri 29 Dec 06 @ 9:58 pm
Match pitch is disabled,reset macth gain is at gain is at always match
geposted Sat 30 Dec 06 @ 2:57 am
try dissabling always match gain , and eq reset
geposted Sat 30 Dec 06 @ 12:01 pm
i tried all that and still nothing..Thanks for the help guys.
geposted Sat 30 Dec 06 @ 3:06 pm
so what ever you change u get high bass?
geposted Sat 30 Dec 06 @ 3:11 pm
No the opossite it drops the bass on the left deck only
geposted Fri 12 Jan 07 @ 12:56 am
glexHome userMember since 2007
I think you have to put your soundcables both to the output 1/2 , not 3/4.
I am not sure if that's your problem.
geposted Fri 12 Jan 07 @ 8:18 pm
