I burned the timecode for cd's. And , it's playing through my speakers. I configured the timecode mode on VDJ. I checked off the cd , smart cue , master tempo , and browser track settings. Then I set 4.2r1 to ASIO mode ,and I made sure my computer settings we're also set to HERCULES AUDIO. Also made sure the HERCULES panel was checked off on ASIO mode. I hit the audio config button , and I got no signal. But, my cd decks was in sync with VDJ. The software looked to be in good response time when I scratched on my cd decks. Also, I still was'nt getting any audio. I only got signal sound from the TCCD , am I doing something wrong? Or am I not setting something right?
geposted Sat 30 Dec 06 @ 5:57 pm
geposted Sat 30 Dec 06 @ 6:01 pm
Read SkyFXL's guide.
Also make sure you get 100% timecode quality signal, when you hit auto-config in VDJ timecode setting.
For CD mode use, choose SMART MODE, and turn OFF anti-skip and browser track (might be off by default).
If you dont get 100% signal, when all of the settings are correct, this may be due to the signal into the Hercules being too loud (Hercules dont have a volume slider for inputs).
So, if you are using Pioneer CD players (CDJs 800/1000) or Denons (3500/5000) the signal is too lound for Herclues. You need to open the mp3 timecode file in a wave editor, and lower the volume by -13db.
That way it will work great;)
geposted Sat 30 Dec 06 @ 6:25 pm
Ok , I've set everything to your configs. It seems the problem could be my volume. I own Denon 3500's , but.... I need details on how to conigure the volume , where do I go to apply this? I have no clue!
geposted Sat 30 Dec 06 @ 8:14 pm
get audacity
http://audacity.sourceforge.net/
and open the timecode file
then reduce the volume - 13db
-9 db
and -6db
then save a copy of each
burn a cd at each of these levels
see which one works the best :)
-9 db
and -6db
geposted Sat 30 Dec 06 @ 8:19 pm
Im really having a problem tyring to save the project in Audacity! It won't let me export as an mp3 file.
geposted Sat 30 Dec 06 @ 9:17 pm
download and install this ;
http://www.free-codecs.com/download/Lame_Encoder.htm
geposted Sat 30 Dec 06 @ 9:30 pm
Export as WAVE file (Wave PCM windows)
And burn the wave file to AUDIO cd
geposted Sat 30 Dec 06 @ 11:07 pm
Alright , i got the encoder. I managed to do everything as you said. I burned three different copies ,-13db, -9db, and -6db. I tried each one and they all work. But , each one one has this beep to it that is pretty loud. If I adjust the volume on the console it does go down. But , then im not getting the volume I want. Also , the signals are at 100% but they constantly fluctuate , on all cd's. Was'nt sure if that was supposed to happen.
geposted Sun 31 Dec 06 @ 12:01 am
no thats not spose to happen
geposted Sun 31 Dec 06 @ 12:10 am
Yeah ,was'nt sure if that was supposed to happen! But , it only changes percentage when I try to scratch.
geposted Sun 31 Dec 06 @ 12:14 am
What you need is 100% quality and seems you have that.
And it WILL go down each time u scratch :) thats all natural.
What do you mean by loud beep ?
Are you hearing the timecode signal in your speakers ?
If you, you have something set up wrong.
geposted Sun 31 Dec 06 @ 12:16 am
Yes the timecode in my speakers.
geposted Sun 31 Dec 06 @ 12:22 am
0n your volume control mute the output of the line in
geposted Sun 31 Dec 06 @ 12:24 am
It means only use the "recording" mode for line in and mute the "listening" mode of it
geposted Wed 03 Jan 07 @ 1:15 am
