Forum: Old versions
Topic: CONFIG MENU SOUND SETUP
hi i am having problems i was using the virtual dj in a party i using a mixer and was playing through the mixer but i was having problems if i use the external mixer and mono output i could on on one speaker and if i use the 2 cards i was having problems with the sound on one of the speaker i did try different setup but i can't find what is the right set up to use can anybody help me ?
geposted Sun 31 Dec 06 @ 12:59 pm
sbangsPRO InfinityMember since 2004
which cards do you use?
have you updated to 4.2 it fixes the second soundcard problem?
geposted Sun 31 Dec 06 @ 1:02 pm
I had a same problem again when i plug in the connection via my mixer the right deck on VDJ the sound coming from that is very distorted and bass is very bad, i have only recently purchased the software but i will check which version i have. I have a dell laptop and a normal sound card in it.
geposted Tue 02 Jan 07 @ 12:15 pm
if you use 4.2
and choose on proformance
"auto latency"
all will be well :)
geposted Tue 02 Jan 07 @ 12:44 pm
thanks for the the useful info
geposted Fri 05 Jan 07 @ 4:41 pm
