Forum: Old versions
Topic: out of sync beats
markdPRO InfinityMember since 2003
i recently started using virtual dj in my iive gigs to replace playing off of cd's on cdx's. I have everything timecoded through cd on the cdx's with virtual dj. The problem i am having is that the beat can easily go off sync. When making ajustments the control doesnt seem to be as good as playing off cd's. Are there any settings i am missing or another alternative that can keep beats synced more accurately?
thx
geposted Tue 02 Jan 07 @ 4:16 pm
sbangsPRO InfinityMember since 2004
which timecode mode are you using?
geposted Tue 02 Jan 07 @ 4:17 pm
I am using cd mode through 2 cdx's, 1 mixer and a firewire soundcard (2 ins 2 outs)
geposted Tue 02 Jan 07 @ 7:43 pm
on the timecode options
there is a drop down menu
Smart
Absolute
Relative
try changing them to see what suits you best :)
geposted Tue 02 Jan 07 @ 7:45 pm
what are the differences between modes?
geposted Tue 02 Jan 07 @ 7:57 pm
abolsute
no software aids
absolutley does what the vinyl does
smart mode helps you out alot with cuing and pitch adjustments
relative , is relative to what you do with some aids
geposted Tue 02 Jan 07 @ 9:44 pm
