I am noticing that many hip hop songs have incorrect bpms often double what they should normally be. Why is this and how can it be fixed?
geposted Tue 02 Jan 07 @ 4:20 pm
did you analize them with "any music"
if you notice they are still off
click on a song and press edit and edit the bpm manualy
geposted Tue 02 Jan 07 @ 4:26 pm
or use mixmeister and vdj database updater tool(thanks norway) ;-)
geposted Tue 02 Jan 07 @ 4:36 pm
what is vdj database updater?
geposted Tue 02 Jan 07 @ 7:59 pm
hip hop is hard sometimes to get accurate counts, the vocals and rhythms might not be constant enough or confuses the scan. Usually what i do is either tap it out (shut up) or if the song has an instrumental version that usually gets the right bpm.
feel frisky??? go ahead and match it by ear!
geposted Tue 02 Jan 07 @ 9:13 pm
(there are two of them but this is the one i have (read the review)
VDJ Database Updater
Name: VDJ Database Updater
Author: macourteau - Team -
Description:
This program can update 2 fields (one of them, or both) in VirtualDJ's database (Comment, BPM) using the infos in the ID3Tag.
Now supports CSV and Tab-delimited files to import BPM's.
USE:
1) Run "VirtualDJ Database Updater" under Start > Programs > VirtualDJ;
2) Choose which field(s) to update;
3) Click on 'Update'.
Review:
Great work ! Hip hop DJ's will love this small app.
Date added: Tue 29 Jun 04
Last update: Thu 8 Jul 04
https://virtualdj.com/addons/download.html?addon_id=446
mixmeister bpm:
http://www.download.com/MixMeister-BPM-Analyzer/3000-2169_4-10290907.html
geposted Tue 02 Jan 07 @ 10:02 pm
