IS ANY ONE ELSE HAVING THE SAME PROBLEM WITH THE RIGHT-HAND SIDE
(DECK-B) JOG WHEEL???IF I ATTEMPT TO DO A QUICK BACKSPIN WITH THIS JOG WHEEL IT STUTTERS OR HESITATES, AND THE DECK-A JOG WHEEL DOES NOT DO THIS IT WORKS JUST FINE. I AM ASKING BECAUSE I NEED TO KNOW IF THIS IS JUST A SOFTWARE GLITCH OR IF MY EQUIPMENT IS DEFECTIVE. PLEASE SOMEONE WRITE BACK..
geposted Wed 03 Jan 07 @ 3:25 am
some steps to take
1. reinstall the console drivers
2. reinstall virtual dj
3. now run the program check if it works
4. if not download the lates direct X http://www.microsoft.com/directx/
5. check for any updates to virtualdj or other windows services
6. Check my blog for tips on optimising your pc.
if still not working check for any physical damage on the unit or any thing jamming the jogs
and try contacting herc support
http://ts.hercules.com/eng/index.php
Good Luck!
sorry to hear of your problem but could you please turn of your capslock it looks like your shouting at other users thanks :)
Regards
Simon
geposted Wed 03 Jan 07 @ 10:46 am
