Forum: Old versions
Topic: Tracks jump when starting play
Hi,
Can anyone help?
When I 'm playing a track on deck 1 and want to start another on deck 2 at a specific point i match the pitch then hit play or sync as the beats match in the 'rhythm window'. When I do this the second track jumps. I've tried it with beatlock on and off and it happens either way. It sounds as if it's just me not being acurate enough at hitting the play button on the beat but wondered if anyone had any suggestions?? i hope so 'cause it's really annoying! :-)
pc spec is:
pentium 4, 3.06ghz
2gb ram.
Thanks very much.
geposted Sat 06 Jan 07 @ 1:11 am
I get this sometimes too.
Start the second track JUST BEFORE you want the beats to match. This usually works for me.
Keep spinnin'...(",)
P
It happens only when you press SYNC, and its intetional
Its the new smooth sync, that wil sync smootly to the CBG's (the dots under the beats in the waveform).
For the old 3.4 sync, right-click the sync button. This will sync straight to the actual beats, and not the cgb's,, and will do it in a more "raw" manner
Excellent, I;ll give all these a go.
Thanks for your help!
Richard
