i'm experiencing serious problems with my vdj 2.0 and 2.01 version , with the autolock and autobeat function.
i was very happy with vdj 1.0 , there was no problem with this functions.
in vdj 2.0 i have following problems :
1) autolock mostly don't work , the two tracks i'm playing are not perfect in sync.
2) autobeat don't work correctly too , after 4 beats of playing music , the tracks don't stay synchronised. i need to push the autobeat button too much for havin the tracks correctly synchronised.
3) cbg are mostly wrong. when i put them correct at the beginning of the song , they will be wrong in the middle or in the end of the song.
vdj 2.0 is working so bad for me , that i'm using my 1.09 version.
geposted Mon 09 Aug 04 @ 2:11 am
I totally agree and empathize with you. After trying various suggestions, I’m still experiencing the same problems. The demo that I tried before purchasing the product is the 1.08 version. I then tried the Traktor demo; however, I went with VDJ 2—I should have tried the demo for VDJ 2 also. This software has too much potential to be performing like this. Although I will not give up on this very promising product, I will use another product until these issues are corrected.
geposted Mon 09 Aug 04 @ 7:05 am
True, with the v2.0, some new beatlock issues arrived. The only problem for me is that now, all the CBGs must be perfect with all songs, IF I want to use samples (otherwise I never use the beatlock function, so it's not a "bigge" for me).
But well, for me samples are just for a fun adition more than a cruital mixing element (though I admit that they are very usefull sometimes, and can help you make an easier mix).
So hopefully, these problems will be solved in a near future and even those who depend on these feature will be able to use them successfully. It's really hard to see a point in features I don't use at all (very seldom to be honest), but this software has so many other advantages that I just have to use it ;)
geposted Mon 09 Aug 04 @ 2:33 pm
