So I just got this 7.1 internal sound card, tested the sound with itunes and sounds great!
So now i have two soundcards
C-media PCI Audio Device (drive date : 8/3/2004)
Realtek AC'97 Audio (drive date : 11/6/2006)
Both work find when using a different sound program, but when I use Virtual Dj the onboard sounds like crap, it crackles! And when i change it around, the headphone crackles. Its back and forth.
I have tried putting the latency on 'auto'. Unchecked Safe Mode, and Unchecked Overclock. I even tried seeing if the IRQ was being conflicted with any other cards, and both of them says "There is no confliction". Please tell me how I can fix this problem, thanks everyone.
geposted Mon 08 Jan 07 @ 3:04 am
I checked my IRQ again, and it seems the "C-Media PCI Audio Device' is set to (PCI 3). which is primarly for printers or lan i think?
I will try to change it to PCI 10) or PCI (5).
However, the audio crackling is coming from the onboard soundcard, the Realtek AC'97 Audio, which is set to (PCI 5) which is primarily for soundcards, so it should be okay.
The audio crackling is not coming from C-Media PCI
geposted Mon 08 Jan 07 @ 3:22 am
I downloaded the DPC Latency Checker, and it seems my wireless card is giving me drop-outs, so I disabled it and started up Virtual DJ. Guess what, it STILL makes the crackle noise! The wireless card is the only thing thats giving me red bars.
I checked my device manager, and my C-Audio is with the same number as my Wireless Card, both on 10. I have no idea how to make them separate pci numbers. I tried going into BIOS but there was nothing, I tried switching PCI slots, still nothing happened.
I am still getting this audio crackle noise, is there any other solutions?
geposted Mon 08 Jan 07 @ 4:35 am
Turn down the Prests slider under settings/performances
geposted Mon 08 Jan 07 @ 5:04 am
Have you updated to the latest DirectX?
http://www.microsoft.com/downloads/details.aspx?FamilyId=77BC0499-19D0-46B6-A178-033D9E6C626B&displaylang=en
geposted Mon 08 Jan 07 @ 5:25 am
I think I found a simple solution
I forgot I could use two outputs on my 7.1 soundcard. I'm using one soundcard, and so far i'm not getting any crackling audio....lets hope this will last! :)
geposted Mon 08 Jan 07 @ 5:32 am
Well for at least 20 days it might.
geposted Mon 08 Jan 07 @ 5:34 am
yeh u should buy it if u havnt or if u have neglected to put your ceral in, go ahead and do that, and buy the program if u can.
its really good program had it for 2 yrs now.
geposted Mon 08 Jan 07 @ 6:07 am
thats right vdj family,have been a user of vdj sence 1.09 i think it was.
geposted Mon 08 Jan 07 @ 6:09 am
Good Try...
geposted Mon 08 Jan 07 @ 1:36 pm
"wessmith is member since 8 Jun 06"
tsk tsk tsk
hehe =)
tsk tsk tsk
hehe =)
geposted Mon 08 Jan 07 @ 2:19 pm
in the bios do you see "intergrated devices"
this is where u will find them :-)
have u checked the general software/ irq guides
https://virtualdj.com/forums/62907/Software_Technical_Support/Asorted_Software_Guides__(common_fixes_and_tweaks_and_how_2_s).html
geposted Mon 08 Jan 07 @ 2:23 pm
