Is it possible to change the volume-function with the gain-control? so that i can control the gain with the volume button on the console.
i don't have the full version of Virtual DJ.
andy
andy
geposted Mon 09 Aug 04 @ 11:25 am
yes.
just go to the settings. then remote controll.
good luck
good luck
geposted Mon 09 Aug 04 @ 5:42 pm
djjb: that would be the invert pitch/volume, not the gain/volume that was asked for.
I guess it should be mappable, but I'm not good at that... :)
Maybe it's something that can be build in into a skin, I'll look into that...
geposted Mon 09 Aug 04 @ 6:28 pm
if you find the way to make it, mail me at : --@--.--
If I find it before... I'll tell you too
Moderated by Lady Cameron
Sorry DjSilex no email address is allowed from a demo user
geposted Fri 13 Aug 04 @ 10:46 am
I ain't a demo user *sigh* just can't find the SC for VDJ
geposted Fri 13 Aug 04 @ 10:48 am
Perhaps using the MIDI-MAP Mode, although the mapper mode never got to work here.
geposted Mon 16 Aug 04 @ 2:52 pm
HI you all,
first off all, the djconsole is great, the only thing is.... the gainbutton
I've searched everywhere, tried everything (exept for the midi remapping) but notting seems to work.
Does anyone has a solution??
P.S. I'm doing a gig this saturday at a local party (Berlaar-heikant, Belgium)
geposted Wed 10 Nov 04 @ 5:53 pm
You can map gain function to a knob or slider at the console, with the console mapper.
But might not work in a cracked version of the software, as they have bad code.
geposted Thu 11 Nov 04 @ 1:01 pm
I have no problem with gain, cause i adjust it with mouse, but for test i have tryed to configure the knobs of volume and now when i move the knob, both gain and volume go up or down.
I have only activate the Default profile in the console-mapper and i have made 4 shortcut in virtual-dj settings
Key E > gain(-150) > on desk 1
Key R > gain(+150) > on desk 1
Key U > gain(-150) > on desk 2
Key I > gain(+150) > on desk 2
Maybe need something to disable the default settings in virtualdj, and permit only to move gain knob using volume knob of console
geposted Wed 17 Nov 04 @ 5:19 pm
