Forum: Old versions
Topic: Numark tt200
Hey sorry for the question again but this turntable should be fine with your program right?
geposted Tue 09 Jan 07 @ 1:05 pm
sbangsPRO InfinityMember since 2004
for timecoding and playing vinyl
yes but remember you need pro edtion
plus a soundcard with two stereo inputs such as mk2 dj console and
u46dj
geposted Tue 09 Jan 07 @ 1:25 pm
so if i wanted to try it out on the demo its a no go then
geposted Tue 09 Jan 07 @ 2:03 pm
And if i hooked it up to bcd2000 would that be alright
will work in the demo for 20 days only
and the bcd will be fine.
geposted Tue 09 Jan 07 @ 2:27 pm
Oh ok thanx again so if i hook it up to my bcd2000 it should work in the the demo? But then when i buy the program do i need to by the pro version?
geposted Tue 09 Jan 07 @ 3:41 pm
yes it will , and yes you need pro
geposted Tue 09 Jan 07 @ 4:28 pm
Why is it the demo will work but then when i buy it i need pro is it because the demo is the pro version but the home version is a step down from the demo?
geposted Tue 09 Jan 07 @ 4:43 pm
the demo is pro
home is the old program before v4
which doenst support bcd
geposted Tue 09 Jan 07 @ 4:52 pm
Oh ok thanx a lot for that cleared things up heaps at least i know if i buy the prog i will have quick responses and great helps cheers
geposted Tue 09 Jan 07 @ 5:10 pm
hope to see u soon as a pro user:) then
regards
Simon.
geposted Tue 09 Jan 07 @ 6:28 pm
