Forum: Old versions
Topic: cue points using vob files
I am using this program strickly for video. All of my files are in vob format and they will not hold the cue points. If i set a cue point it will stay untill i restart my system. when I restart the system the cue points are gone. What a pain in the A**... LOL. Please help me out. Thanks, Mike
geposted Thu 11 Jan 07 @ 6:50 pm
The cue points are saved in the XML database.
Are you sure you're not restarting VDJ too soon? (needs a few seconds to save the database, so dont restart the app right away)
Or close the PC down, before database is saved.
You can also try to manually save the database, with shortcut...
geposted Thu 11 Jan 07 @ 8:28 pm
You know, I'm not sure. I think I am simply closing the computer before I shut down the program. I will check it out by doing a couple videos as a test and get back to you. Thanks
geposted Thu 11 Jan 07 @ 8:45 pm
Dont ;) That will for sure NOT save your cues;)
geposted Thu 11 Jan 07 @ 8:48 pm
Not to mention setting yourself up for possible disk corruption. Always shutdown Windows properly.
geposted Fri 12 Jan 07 @ 5:44 am
OK, it worked. thank you for your help everyone. I was shutting down by simply hitting the power botton on my laptop and and closing the lid. But I did a manual save before hand and this morning it was all still there.
geposted Fri 12 Jan 07 @ 5:26 pm
