Forum: Old versions
Topic: is there a way
I mix in relative mode, but one problem I have is if the timcode runs out on me & I'm not paying attention....the music stops (because theres no more timecode)
& please don't say I should be paying attention.
Is there a way to make the program switch to internal mode when the timecode runs out?
If not that should be added. :"
geposted Sat 13 Jan 07 @ 7:55 am
yeh it should, sky agree with me??????
sky is really respected round here, cant u tell? not saying none of the other members rnt its just hes really respected round here! runt u sky?
alas there currently is an issue with this im hoping it will be fixed soon , so it doesnt stop in smart mode
the fix is to deactivate the timecode on the software just before it runs out
using a keyboard shortcut , or the icon under the decks
any luck with this??? Its an ongoing problem for me. I'm so used to just letting the record ride in relative.
PLUS lets say you do catch it before it runs out......it still a problem becuase lets say you switch back to internal mode b4 it runs out, if the vinyl is @ +3 percent.....when you switch to internal its goes back down to 0%. So its going to go from +3% (with vinyl), 0% (in internal), & back to 3% when you activate the vinyl again. That NO Good! If I'm doing something wrong, let me know I'll gladly take the smack.
I'm glad to help with as much needed input as possible to make this a one of the best programs. PM ME! But if you don't start doing someting soon you're going to get left behind in the dust! Theres way too many companies doing this ish now.
Theres alot of very simple things that need to get modified, but aren't given much attention to. I know most of the people on this forum mix dance music, but thats not the case over here in the states : ( its sad but true.
{{{{{{{{{{{{{{{ Gimme your thoughts people }}}}}}}}}}}}}}}}
