i dj private parties and sometimes i have to make a list on the fly for a bunch of different music categories.
having the ability to have a table of "sidelist" would help me out so much.
it's like a play list on standby.
now i know all about the "virtual folder" but it's not the same.
ideally, there would be no limit to the number of side lists availiable. but practically, i think 6 side lists would be awesome. the GUI would look something like this
[DEL] [ADD] [SIDELIST] | 1 | 2 | 3 | 4 | 5 | 6 |
DJ Shahar
www.djshahar.com
DJ Shahar
www.djshahar.com
geposted Sat 13 Jan 07 @ 10:59 pm
Another great idea would be to add a sidelist called "Preview Only"
pressing "enter", "double click", "crl+enter", what have you, will PLAY the file in preview mode.
it would be like a regular cd player with the regular player controlls "back, pause, play, next"
current song is highlighted
played song is not removed.
DJ Shahar
www.djshahar.com
DJ Shahar
www.djshahar.com
geposted Sat 13 Jan 07 @ 11:15 pm
well, i think, i understand the point,
but i don't need "that" many sidelists :-)
another solution would be to toggle the playlist
usually in automix mode or when you load/drag songs, the songs will disappear from the playlist after loading
how about having an option, that only appears or can be activated if the automix mode is "disabled",
to be able to switch the playlist to a sidelist
happy vdjing,
matt
happy vdjing,
matt
geposted Mon 15 Jan 07 @ 8:27 am
my idea is having the abitlity to create and use 6 sidelists. you have the following buttons
[DEL] delete viewing sidelist
[ADD] create new side list;prompt for name(default is last sidelist # +1)
[SIDELIST] resize height of sidelist
| 1 | # or name representing the side list (max: 10 char)
you start off with 1 sidelist. click on "ADD" and create another sidelist. max: 6
you can search for romantic songs in your virtual romance forlder and make a sidelist "romance"
the playlist of your romance songs in the order you want it.
so on and so on. client asks you to switch genres, "no problem, sidelist, eh, play list is ready"
DJ Shahar
www.djshahar.com
DJ Shahar
www.djshahar.com
geposted Fri 19 Jan 07 @ 9:26 pm
