Dac Usb Error
I am at a loss, I am tryin to install my DAC on my system and when I plug it in I get Unrecognized Device. No matter what I do I can't install the drivers. When I turn the DAC2 on I get the 3111 then it turns off like it is supposed to. I think this is an error as the DAC 2 is not recognized as a Windows device. Any help, I know there have been others with this same dilema
geposted Mon 15 Jan 07 @ 8:11 am
do you have the latest driver version , ?
Click me to update!
Click me to update!
geposted Mon 15 Jan 07 @ 10:17 am
Sky it has nothin to do with the Drivers. The problem is that Windows is sendin an error that this is an unknown and/or malfunctioning device. Now I am gonna try the DAC back on the Dell that it was workin on when I took it off Friday. I have tried all kinds of stuff ie. removin the USB from windows and lettin it reinstall the USB drivers and such. Now it was seein the device as a DAC yesterday but I never got the drivers installed. today it is an unrecognized device.
geposted Mon 15 Jan 07 @ 11:24 am
unregonised device in human speak means
missing driver or currupt driver
if you look on the device manager page you will see a little yellow icon asking you to install it
right click and press update driver and choose that driver file now hopefuly it should now work :)
as the dac is a human interface device it doesnt always need a driver , it can be picked up with out it but give that a shot ,
could be a snapped cable or damaged usb port aslo.
geposted Mon 15 Jan 07 @ 11:39 am
brian, load the drivers. Matter of fact, with the DAC you should install the drivers before you connect the DAC to the machine.
geposted Mon 15 Jan 07 @ 5:20 pm
Sky I tried all that and I am tellin you there is no yellow question mark, it is showing as Unknown Device and when I try the drivers it says Windows can't find a better driver for this device, however there aren't any drivers installed nor will it let me install. I have tried this on several USB ports and every time it is coming up as an error and/or malfunction.
geposted Mon 15 Jan 07 @ 9:31 pm
on all ur pcs?
because if thats so could be a damaged dac
geposted Mon 15 Jan 07 @ 9:45 pm
skyfxl wrote :
... could be a snapped cable ....
If you've allready tried this then it's certainly a damaged unit. Send it back and get a pair of BCD hehehe ...not recomended.
geposted Mon 15 Jan 07 @ 10:20 pm
3 days ago it worked on a different pc. I am gonna try it again on another PC. It really doesn't matter if I get it working as I really only use my MK2 and X-Session. I will let you know.
geposted Tue 16 Jan 07 @ 12:02 am
