Forum: Old versions
Topic: MK2 Help Urgent
Hello Everyone
Last week I posted a topic about my hercules console not working properly.
Every time I have to use it I have to re install the drivers or it would not let me change to dj mode.
Anyway this sunday I bought the MK2 but is not working either ( F.........................K)
But now I can't disinstall the drivers from the hercules to install them again.
Is there a tool to help me to erase and di install the Hercule Drivers???
I know there is one for VDJ but I try to di install VDJ too and that din't work either.
Some one suggested to update the DirecX drivers. How do I do that???
I hope somebody can give me a hand on this.
Honestly I am so frustrated with this product, now I can't use anything, I have a gig tomorrow, I am in the middle of the ocean and I can't go and try to buy anything else.
As I said ealier Hercules is really unrealiable, is only given me problems since day 1
geposted Mon 15 Jan 07 @ 6:06 pm
sbangsPRO InfinityMember since 2004
do you get a particular error message?
geposted Mon 15 Jan 07 @ 7:51 pm
"dj mode"
you are using old drivers, update to latest drivers from Hercules.com
geposted Mon 15 Jan 07 @ 9:21 pm
the error code 5001
The drivers so far I know are the latest version.
I can't change from wdm to asio for the MK2
Or Normal to dj mode in the old console screen.
In any case even if had any newer version my Proble is I can't disintall the other ones to beging with.
I already updated the DirecX drivers in case that have something to do with it, and I really don't think is my System ( Dell XPS 1210 Centrino Duo 2.2Mhz 1G ram).
How do unisntall this drivers???
geposted Mon 15 Jan 07 @ 9:55 pm
Also please tell me something why is it that every time I plug the console
my system tells me "new hardware found" and it ask me to install the drivers like it doesn't reconize it.
I usually I just ingore it but may this has something to do with it.
F.........k I really want to kill somebody right now
Hercules is a pice of crap.
I can beleive I fell for it again.
geposted Mon 15 Jan 07 @ 10:01 pm
go to startmenu > control pannel
add remove programs ,
choose mk1
unintstall
then if you aslo have a mk2 install uninstall that 2
then grab the latest drivers
http://ts.hercules.com/eng/index.php
and install them
geposted Mon 15 Jan 07 @ 10:50 pm
Correct and ALWAYS PLUG MK2 into SAME USB PORT.
geposted Tue 16 Jan 07 @ 9:00 pm
or any usb on the same bus
geposted Tue 16 Jan 07 @ 10:26 pm
Ok I will try that
thanks everyone.
geposted Tue 16 Jan 07 @ 10:59 pm
