Hi,
Does anyone know how I get rid of the whistle my decks produce?
I've got set up;
VDJ Pro v4.2r1
2x1210's with TCV (grounded to the DJ Console)
DJ Mk2 Console
Technics 1200 External Mixer
All works fine (thanks goes to SKYFXL) but the whistle is going to see me in a mental home, it drives me nuts!
I've tried the standard mute all stuff in the instructions to no avail.
Thanks
J
I've got set up;
VDJ Pro v4.2r1
DJ Mk2 Console
Thanks
J
geposted Mon 15 Jan 07 @ 6:27 pm
I give my cockatoo crackers…. LOL : P
geposted Mon 15 Jan 07 @ 8:01 pm
do you mean the noise the needle makes ?
is it comming out of your soundcard?
geposted Mon 15 Jan 07 @ 8:48 pm
it comes from the needles
geposted Tue 16 Jan 07 @ 10:19 am
the way turntables work is via the needle running through the grooves , which im sure u know :)
the sideffect of this is around the needle you can hear the sound of the record playing , the timecode is a series of highpitched pulses of 1010101 , so what you are hearing is the noise it makes when it vibrates and there is not much that can be done about it as far as i know.
this is the same on all timecoded vinyl or any vinyl
hope that helps
hope that helps
geposted Tue 16 Jan 07 @ 10:46 am
different needles with also make a difference, as long the sound is not coming out of your output dont worry. Make sure you mute the input in the soundcard options.
geposted Tue 16 Jan 07 @ 4:19 pm
the mk2 should prevent the timecode noise comming out the output :) automaticaly
geposted Tue 16 Jan 07 @ 4:25 pm
