Hi,
I am currently using the trial version of Virtual DJ 4.2 and think its brilliant! I'm having a problem previewing a 2nd track in the headphones to hear what it sounds like before I mix it in - can anyone point me in the right direction on how to do this?? Thanks.
geposted Wed 17 Jan 07 @ 12:21 pm
you need a 4.1 + soundcard
choose out put :headphone
and your soundcard 4.1 if 4.1 5.1 if 5.1 ect
choose , the channels you would like to use for headphone or main
geposted Wed 17 Jan 07 @ 12:30 pm
Thanks! I will have to check what soundcard I have - can these options be changed in the Config menu at the top of the screen, or is it elsewhere??
geposted Wed 17 Jan 07 @ 1:05 pm
go to the config window
then sound options.
you can easily tell what general soundcard you have by looking at the number of outputs
then sound options.
geposted Wed 17 Jan 07 @ 2:48 pm
