Hi even after the new update i still have a dreadful clicking in my headphone
wasnt there before the last 2 updates
same problem on my Laptops
Both 1 gb Memory and 2000+ CPU 64 mgb video
1 is dual core as well
PC has 1.5 gm memory and 2200 cpu 128 mgb Video card
its suck a horrible clicking noise
please help as i have to uninstall and put older version back on
geposted Wed 17 Jan 07 @ 8:33 pm
In VDJ PERFORMANCE tab...
Set latency to : AUTO
turn off safe mode and overclock
geposted Wed 17 Jan 07 @ 8:41 pm
Hi thanks for the help
seems to be a bit better but still there
if i take off safe mode its terrible if i leave it on and leave off overclock its not too bad but still very off putting when trying to beat lock manually
i have tried all the presets and sometimes the clicking goes away for a minute or two but then returns
geposted Wed 17 Jan 07 @ 10:41 pm
try some of the optimisation tips in my blog :)
geposted Wed 17 Jan 07 @ 11:02 pm
If you turn safe mode off, it sounds horrible you say.
Please try to lower the performance slider.. I think you're trying to run VDJ at a too high setting for your PC ..
geposted Wed 17 Jan 07 @ 11:20 pm
if your not sure how
check this :)
and follow norways tips :)
check this :)
geposted Wed 17 Jan 07 @ 11:22 pm
Hi tried them all on my PCs and Laptop
i have a 3 week old Samsung R40 Intel dual Core with 1 mgb memory 80 gig hard drive with no other software
and its still clicking
ive tried all settings even reebooted after them all
still click click lol
think i will uninstall it and return to the older version :(
thanks for help but mate cheers
geposted Thu 18 Jan 07 @ 2:05 am
geposted Thu 18 Jan 07 @ 7:41 am
By any chance, do you have a webcam hooked up to your PC? If so, unplug it and reboot. I noticed a similar problem with another audio program, and found that the webcam was causing the issue. It was due to the internal mic on the webcam. Very strange.
geposted Sat 20 Jan 07 @ 9:38 am
