I've used every post in this place to get the settings right but for some reason mine will not configure and keeps telling me to check my cable or volume level. Any extra help would be needed. Thanks in advance.
geposted Thu 18 Jan 07 @ 12:02 pm
what soundcard?
what version of vdj :)
which cd players?
which cd players?
geposted Thu 18 Jan 07 @ 12:10 pm
DJ MK 2
It came with the basic version(which I still can get off the comp), but previous owner of the computer said he had the basic version then upgraded what I believe is 4.1 or 4.2. Im really horrible with computers so i can try to give as much info as possible.
2 Denon DNS-1000s
2 Denon DNS-1000s
geposted Thu 18 Jan 07 @ 4:54 pm
When I get it up and set up to configure its like the track just goes crazy and is stopping and studdering.
geposted Thu 18 Jan 07 @ 4:55 pm
alright add your mk2 to your profile
https://virtualdj.com/fusers/modifuser.html
ensure you have the latest updates
now does the wavform fill the screen on the config window or is it very big?
geposted Thu 18 Jan 07 @ 5:43 pm
it will be nessary to use pro if you wish to use timecode for more than 5 minutes which is to allow you to test.
geposted Thu 18 Jan 07 @ 5:44 pm
The waves go up and down and shows signs of movement.
geposted Thu 18 Jan 07 @ 7:32 pm
add your serial plz and get the latest update :)
geposted Thu 18 Jan 07 @ 8:24 pm
