Hi,
When my MK2 Console is plugged into my PC my iTunes won't play. It starts up but won't play a song.
I'd like to be able to play iTunes when I'm not on VDJ without having to unplug the console everytime.
So, is it possible to keep the MK2 plugged in and play iTunes?
I guess it must be, so if anyone knows the right config set up it would be appreciated.
I've read the IRQ thread but I'm not sure if I need to follow it.
Thanks
J
Thanks
J
geposted Thu 18 Jan 07 @ 8:02 pm
yes the console is a soundcard for all programs , it should work just fine with itunes
are you getting any error messages?
geposted Thu 18 Jan 07 @ 8:08 pm
I'm getting an error message saying "iTunes has deteted a problem with your audio configuration. Audio/Video may not play back properly"
I can only guess it ismaybe because the PC is seeing the USB before the main soundcard and it doesn't like it?
When I unplug the console it works. And when I plug a mini jack into my internal soundcard into my amp it works again.
Cheers
J
Cheers
J
geposted Thu 18 Jan 07 @ 8:22 pm
