Forum: VirtualDJ Skins
Topic: Can I edit the exsisiting Default skin?
I wanted to make it so when I hit the keylock button, it would turn on or off the master tempo instead of keylock.
Can someone walk me through this. Is there a line that has to edited in the xml file?
geposted Thu 18 Jan 07 @ 11:45 pm
open the xml file of the skin you want to change with notepad. Use "find" command to find the "kye_lock" action. Replace "key_lock" with "master_tempo" (for both chanels), save the xml file and give it a try. Hope it works for you.
okay I found key_lock & replaced it with master_tempo......but it does not engeage it. Any suggestions. I know the edit did take because keylock doesn't work now "because I did the edit" There should be a different code to engage the master tempo. Anybody know what it is?
Try...
<button action="key_lock" chan="1">
Change to...
<button action="master_tempo" chan="1" value="0">
Repeat for Channel 2
no that didn't work either.
I did figure out that either one (master_tempo or "master_tempo" chan="1" value="0">) will work when the timcode is turned off. So if I turn off the tc & change the pitch on the track, the master tempo does work. How do I get this to work with the vinyl?
thx 4 replys
bizump
