Forum: Old versions
Topic: Final answer on macbook... anyone? - Page: 2
Steve Lynch wrote :
I'm looking at purchasing my 6th mac, and I'm probably gonna' get a mac book pro.
I've read that the video out doesn't work in bootcamp.. can anyone confirm or deny? also, is the intel extreme graphics chipset adequate for video use?
Your are correct. S-Video or Composite video output does not work with the apple video adapter in bootcamp. That doesn't mean you can't use bootcamp to dj video since you can use the DVI output to get a second monitor to work in bootcamp. The solution to your problem is to buy a scan converter which converts DVI/SVGA into a composite or S-Video signal.
As for the intel extremem graphics chipset it is not not adequate for video use so you will have to buy the mac book pro with the ATI graphics chipset.
geposted Tue 27 Mar 07 @ 1:18 am
jchiarPRO InfinityMember since 2005
Hey Steve,
How did you geta beta tester for MAC?
I remember you from PEECEE DJ forums...
If fact, how can i get to be a MAC beta tester??? ( beside some stupid post count)
I am sure my knowledge and support experience must count somewhere !
geposted Tue 27 Mar 07 @ 10:51 pm
