Hello, I have done all the tweaking possible, turn on auto latency, performance slider all way to left then all way right, fast tempo, simple algorithm, and basic interpolation and i still hear a tad bit of distortion. i have my turntables grounded to my laptop. my virtual 3.4 sounds way better. Do u kno what i can do to acheive the same audio engine.
Second question.....why do i hear music out of both turntables, but the signal present always says 0%??????
geposted Thu 25 Jan 07 @ 10:05 pm
geposted Thu 25 Jan 07 @ 10:09 pm
IF 3.4 works fine why would i look up irq settings. Anyway i looked up IRQ and i seen 8 things in port #11. There are 4 usb controllers, mobility raedon 9000, 2 smart card bus controllers, and broadcom integrated controller. Is there a conflict since 8 devices are on one irq #11
geposted Thu 25 Jan 07 @ 10:43 pm
well you have a modem/internet card on the same as graphics so it might be an idea to change those ones
the usb ones dont worry
geposted Thu 25 Jan 07 @ 11:00 pm
after disabling my internet connection , i have better sound. I still cannot maintain a 100% timecode signal. it keeps saying 0% is that a glitch?
geposted Fri 26 Jan 07 @ 4:28 am
Try changing latency to Auto under performance settings.
geposted Fri 26 Jan 07 @ 5:14 am
try making a larger asio buffer
geposted Fri 26 Jan 07 @ 2:08 pm
i already tried auto latency that still makes my tcv signal 0%. what should i increase the buffer to? I have the Asio settings from a blog you referred me to.
geposted Fri 26 Jan 07 @ 2:53 pm
try increasing it in small steps until you get a good singal :)
geposted Fri 26 Jan 07 @ 3:06 pm
it still sounds crappy. i guess i should try to reinstall again. please allow me to do a fresh install. whats the procedure doing a clean reinstall
geposted Mon 29 Jan 07 @ 3:27 am
uninstall then use the regristy cleaning tool
https://virtualdj.com/addons/tools.html
then reinstall
then reinstall
geposted Mon 29 Jan 07 @ 11:12 am
