I think I found a bug in the backspin, downloaded from the sound effects page. When I try to do a backspin on deck 2, the backspin actually is executed on the song in deck 1. The music on deck 2 continues, but VDJ is mute. When I deselect backspin, deck 2 is again audible.
I copied backspin.dll from VDJ 3.4 manually to folder of VDJ 4.2, and there's no problem anymore.
I searched this forum on 'backspin', and didn't find a similar post. So I hope I'm not doubleposting.
Greetz
Greetz
geposted Fri 26 Jan 07 @ 1:16 am
i have the same problem thank u for the info
geposted Fri 26 Jan 07 @ 2:59 am
Damn, i just found the same bug...
needs to be recompiled
geposted Tue 30 Jan 07 @ 8:56 pm
The plugin has been updated , please check the downloads area
Thanks
Thanks
geposted Wed 31 Jan 07 @ 1:55 pm
Thanks
Thanks
Thank you, sir.
geposted Wed 31 Jan 07 @ 8:48 pm
geposted Thu 01 Feb 07 @ 8:42 am
I found that the effect 'beat break' has just the same bug as 'backspin' had; if I use 'beat break' on deck 2, it's executed on deck 1 and everything is mute. Seems horrible when you're using VDJ 4.2 r1 live.
Could someone repair it like it has been repaired for backspin?
Thanks.
Thanks.
geposted Sat 24 Feb 07 @ 1:43 pm
