Forum: VirtualDJ Skins
Topic: BCD 2000 Skin
The V-BCD 2000 (1024X768) skin is now updated
Waiting for your remarks
geposted Fri 26 Jan 07 @ 2:21 am
Getting there…
Rhythm window looks awkwardly large,, and the A B for deck to..
Are you going to got the other button working?
I like It
Thanks paulettecerra
I think that all the buttons are working, but they don't all light up. I don't know if i'm doing something wrong here, or it has to do something the way the mapper handles the control. I hope that Moramax should help a little, if he could.
For example pressing the stop, it responds but it doesn't light up in the skin. Pressing with the mouse it works. This happens also with other buttons such as loop+, loop-, pitch bend.
Updates will be comeing every time i fix a few things. Next update will have panels for sure.
Please post when you update.. The skin area doesn’t display when skins are added or updated..
can you have the buttons suppress when pushed?
Thanks
