a safety option for the unload action
something like "do not unload when deck is playing"
next to where you can select the decks
just to prevent accidents ;-)
geposted Sat 27 Jan 07 @ 1:04 am
already implimented ensure that Security is turned on in options ;)
geposted Sat 27 Jan 07 @ 1:05 am
i'm sorry, but that is not true
the security option that you are talking about is for loading "only"
in other words if you are trying to load a song on a deck that's playing it'll either ask you if you are sure
or put the song into the playlist, depending on the security option you selected
what i'm talking about is
when you're playing on one deck and would like to unload the other one
(please don't ask for the reason... long story... :-(
old habit from my old & weak laptop)
you hit the shortcut and accidentally unload the song on the active deck
which of course will cause the music to stop :-(
geposted Sat 27 Jan 07 @ 1:48 am
- Confirmed -
geposted Sat 27 Jan 07 @ 9:29 am
owch definately somthing must be added thats potentialy dangerous
geposted Sat 27 Jan 07 @ 12:07 pm
yup i agree. others would like to use unload frequently but would be prone to accidents.
this "Ask" would be useful for those who have 512MB or lower memory, which apparently isnt enough to run the program, and have to unload the other deck all the time.
(coz having 2 tracks loaded slows down the program despite playing with all Max load, sound card settings).
with version 3.4 u dont have to worry about unloading. but with v4+ even with the most minimum settings, unloading is a must if u have 512MB even if the tracks have already been analyzed.
geposted Sat 27 Jan 07 @ 7:41 pm
