Forum: VirtualDJ Plugins
Topic: MASTER AND SERVANT -- VST
ejunkHome userMember since 2007
hey atomticmixers:
nice to have vst plug-ins BUT
i want to use a master plug ..say a finalizer/gate/eq
when i switch plug-ins manually i can activate more
than one plug-in (nice for a finailizer plug) BUT
when i use the plug-ins from the interface next to
the turntable animation, no additional plug-ins work
THATS WHAT I CALL A BUG
for real, vst fx make no sense when i can't have a
master plug
geposted Mon 29 Jan 07 @ 11:13 am
sbangsPRO InfinityMember since 2004
you cannot use vst instuments
just basic fx
geposted Mon 29 Jan 07 @ 11:39 am
..sorry, i'm plain talking about vst effects here
what else is a finalizer or equlizer ..that's an effect
if i like to use instruments i'd use other software
(..a drummachine in snyc would be a nice one)
SO ..how can i activate more than one effect
and still use the effect button on the interface
(i mean: use the effect button works, but any
second ..man that's stupid ..i leave it here ..blabla
geposted Mon 29 Jan 07 @ 11:43 am
sorry dude, that is really a bit dry what you are telling me .. indeed
geposted Mon 29 Jan 07 @ 11:46 am
go to the fx tab on 4.2 and Press activate the ones you want then on the main skin use the drop down menu on the main skin to adjust parameters
or you can make keyboard shortcuts to activate Fx , or use a controler
you will find that some multi folder vst's wont work however
geposted Mon 29 Jan 07 @ 11:51 am
..when i activate the plug-ins in the fx-tab ..and THEN use the main skin button
the effects (i've chosen before) are resettet
..means: if i have the flanger and filter ON via the fx tab ..they switch OFF when
i use the backspin on the main skin
..means: i want to use sound effects (filters, finalizers eqs) ON and go on mixing
as normal using the main skin ..using the backspin button ..that does not work
geposted Mon 29 Jan 07 @ 12:21 pm
use the fx tab area then :)
or keyboard shortcuts
geposted Mon 29 Jan 07 @ 12:25 pm
