hey ya'll.... i downloaded the trial version after hearing about this totally rad software... it loads alright... but i'm not able to add any effects(i have only 7).... when i click on it.. it says "unable to open xml plugin file".... the same thing works at my budy's place.... help me fellas!!!! i've formatted my system 2 times already.... still it does'nt work!!!!
geposted Mon 29 Jan 07 @ 12:45 pm
dont use effects downloaded off warez sites they are all wacked and are for out of date versions
geposted Mon 29 Jan 07 @ 12:47 pm
no man... i have only the ones that came with the software... i've not got any new ones... these ones are not working....
geposted Mon 29 Jan 07 @ 12:49 pm
with the latest 4.2 demo?
ok go into the program folder and go to the plugins folder and delete the file plugin.ini
and rerun virtual dj should now work
geposted Mon 29 Jan 07 @ 12:52 pm
thanks for listenin ma... but..... i dont have such a file in my plugins folder !!! is it kinda bad???
geposted Mon 29 Jan 07 @ 12:55 pm
do you have any ini files in there?
geposted Mon 29 Jan 07 @ 1:05 pm
none man..... theres one called "beatgrid.ini" in the sound effects folder....
geposted Mon 29 Jan 07 @ 1:09 pm
should have one for each fx
try a reinstall
but ensure you have the latest demo installer
https://virtualdj.com/download.html
4.2
try a reinstall
4.2
geposted Mon 29 Jan 07 @ 1:15 pm
will do... thanx man....
geposted Mon 29 Jan 07 @ 1:16 pm
good luck :)
geposted Mon 29 Jan 07 @ 1:19 pm
It's not .ini files as the error says a .xml file
Remove the file called "plug_in.xml"
geposted Mon 29 Jan 07 @ 10:13 pm
