hi there peeps!
would any one know where or what software i need to convert wav and mp3 files to vdj files so i can use them as samples on my hercules?
many many many thanx
DJ De'Mensha
DJ De'Mensha
geposted Thu 01 Feb 07 @ 8:42 pm
You can use mp3 and wave straight in the sampler... just load them up in a sampler slot;)
the VDJ format, is really OGG, because that is better for seamless loop creating ..
You can also just load the mp3 or wave to one deck, make a perfect loop at the length you want, then press record in a sample slot. Choose save, and you have it saved in *.vdj format :)
geposted Thu 01 Feb 07 @ 8:45 pm
Norway after the upgrade to 4.2 I cannot load any mp3 into sampler. They do not play?? Any ideas.
geposted Thu 01 Feb 07 @ 11:33 pm
Works fine here, just tested again to make sure...
When you choose "load" you need to choose "show all files" to see mp3s
geposted Thu 01 Feb 07 @ 11:36 pm
Thanx so much guys !!
again you guys are true stars.....:)
geposted Fri 02 Feb 07 @ 8:51 pm
I had to change the MP3 codec and now it is all good. I will let you know what I changed it to later.
geposted Sat 03 Feb 07 @ 2:24 am
hey folks im trying to convert the vdj files to mp3 or wav... is there any converter???
what i'm doing is saving samplers made with vdj cause its easy-to-use but i'd like to use them for another software which only allows mp3/wav format. or is there a better way to sample tracks and save them??
thx for ur help
thx for ur help
geposted Thu 22 Mar 07 @ 6:00 pm
