Forum: VirtualDJ Skins
Topic: BCD2000 SKIN ??? QUESTION
HI
I'm planing to buy VDJ PRO. but steel have some (¿¿¿¿¿?????????)
in the demo version 4.2r1 I have to press bottosn two times to get it work. is this posible to fixed in this skin.?
can you make it 1280*1024.?
I can't download for the moment but I have to be sure before spend $$$$$$ my money.
thanks for reply
geposted Fri 02 Feb 07 @ 4:50 pm
From the setup control of BCD200 select B-DJ mode and not advanced , so you don't have to press twice the buttons.
So far two available skins but both in 1024x768. Soon more will come in 1280x1024. I'm planning to make one soon (next month maybe). As a professional level you will be able to use a plugin called Skin resizer, which works for few skins.
