Forum: Old versions
Topic: No EQ changes in headphones
Hi there...
Short question:
Why can I not hear any differences in sound through my headphones when turning the EQ knobs??
Is that supposed to be like that, is there a reason for this?
Or did you dev ppl. just forget about this? eheh... dont think so.
I am using the BCD2000 and VD 4.2.
Btw.: Will future versions support all 4 FX knobs instead of the currently 2 only? And what about the "Back to top" button? I realise its doin something, but 4 sure not goin back to top.
Appart from that: respect, grate software there!
Regards,
fast_food
geposted Fri 02 Feb 07 @ 5:27 pm
You need to use DJ Cels registry tool, to enable EQ in headphone
You can also change it manually, in VDJ registry. If you feel comfortable using regedit.
String you are looking for is EQHeadphone.
Very soon a general mapper for all midi devices will be released, with that, you can map the BCD2000 any way you like, to your own prefferences
Hope to see you as a full member soon;)
Ok... nice one! :)
Hi everybody, i am having the same problem, can you tell me more details about how config this settings in regedit?
Thank you.
bye
Ok! I found it. The name of the registry key is EQInHeadphones, in the regedit program go to HKEY_CURRENT_USER/Software/Virtual DJ, the default value is 0 you have to change the value for 1.
thanks people. :)
