I am having a problem previewing when using VDJ. The sound card I have is the Sound Blaster 128 4.1 PCI. Its old but it should work right? When I hook my headphones up I hear the same thing as whats on the speakers. I have tried messing with all the settings under config and still nothing. Any one have any suggestions?
geposted Sat 03 Feb 07 @ 3:19 am
did you choose headphone mode and assign channels
aslo check at the top of vdj there is a slider called cue / mix make sure its at cue if you wish to hear the cuing of each deck
geposted Sat 03 Feb 07 @ 12:23 pm
yes I chose the headphone mode / assigned channels. dont know what else to try/
geposted Sat 03 Feb 07 @ 7:26 pm
Im having the same problem and tried the solutions above to no avail.
Can some one help????
Thanks
Thanks
geposted Mon 12 Feb 07 @ 2:43 am
are there any settings you need to change on the windows control pannel or the soundcards control pannel to ensure its set to 4.1 sucessfully
have you tried changing the channel assignments
geposted Mon 12 Feb 07 @ 2:51 am
That was my problem a while back; those sound card control panel
things have to be changed sometimes too for correct configs.
geposted Mon 12 Feb 07 @ 2:52 pm
damn, i have the same exact issue as we speak...
its a bit frustrating...but im assuming its something very basic that im just missing...
any advice would be greatly appreciated...
frankie
frankie
geposted Fri 23 Feb 07 @ 9:23 pm
Does any body now what is the perfect sound card for virtual dj? thanks!
reply at djviola1@gmail.com
geposted Sat 24 Feb 07 @ 5:31 pm
